Simon Torr
Wiring a garage with SWA. (domestic)
Two double sockets and two way lighting
I have a split board, RCD protected on one side, taking a feed from the RCD protected side from 20a MCB, via SWA to D/B with 20a RCD and 16a MCB for sockets and 6a MCB for lighting.
The run will be under 2 meters so Voltage drop will not taken into account.
I plan to use 2 core and earth or two core and use the armouring to provide the function of the CPC and wire accordingly (banjo).
Okay so far. ?
This is my fourth year, after three years at collage, so still have a long way to go.
Now my mentor/instructor has said to use four core SWA, so I have looked in my books, learning lounge and spoken to other electricians, and at a loss with terminating the D/B s with four core SWA, or even using four core for this work.
Help is required, any information would be helpful and appreciated
Okay so far. ?
