- Reaction score
- 0
Hello can anyone offer and advice on running power to an workshop. All work will be done by a professional electrician, I am merely seeing if my idea is feasible. So far I have 6mm swa prysmian cable buried according to reg, sand bedded and warning tape over etc 6.5 metre run.
I have recently had a new electric oven installed which is 240v 2075w. I have an unused switched supply on the kitchen ring main for an old baseboard heater.
Would the following be possible, connect the over to the unused 13amp switch, use the oven supply which is a 32amp supply with a dedicated rcd in the main panel to power the workshop?
The total distance for the shed including the existing cooker feed is 16 meters.
I am planning to run the trunking for the internal cable when I rip out the kitchen.
As I said I will not be doing any of the electrical work and will get a professional electrician to do it but wanted to know if the concept will work or if I am missing something obvious.
