Discuss Wylex NB20 type 2 rcbo replacement in the UK Electrical Forum area at ElectriciansForums.net
Does anyone know if there is a replacement for the wylex NB type 2s. I need to add rcd protection to an existing circuit but unsure if there is an rcbo that will replace it or do I fit a separate rcd?
Pretty sure Wylex never made an rccb to fit those but I believe you could get a two module rccb made by a third party at the time but I would go down the separate rcd route.
I vaguely recall seeing some two module rccbs made by a company called Stotz Kontakt which is often just SK on the device, they definitely produced mcbs that fitted Wylex NN boards whether for Wylex or indirectly I don't know but SK breakers in these boards are not uncommon.
FWIW I would talk to the customer about the pro's and con's of changing the CU ...
To be honest I think I've just come to the same conclusion. Seems quite difficult to get hold of any NB type 2 in good condition. Especially the 30A and 40A. Plus he's got NO spare ways at all.
I will speak with the client tomorrow.
Reply to Wylex NB20 type 2 rcbo replacement in the UK Electrical Forum area at ElectriciansForums.net
My builder has sprung a job on me. New circuit required for a hob. The CU has a single 30mA RCD, type AC. I am still unsure exactly when I should...
I’m probably going to look stupid here, but it will be worth it if I get the answer 😆, as I can’t fathom it out. I’ve never really thought of it...
What are people fitting in the 3 phase range just lately, I've had a scan at various makes and it seems to be a ---- up between Hager and Wylex at...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
