Discuss Zero rate vat to sub contractors in the Business Related area at ElectriciansForums.net
J.C.E
Morning guys
I am doing some new build flats that qualify for zero rate vat. So I am charging vat at zero % to the main contarctor.
However I have a lad working for me (labour only) on the job but he is VAT regiestered. I deduct his CIS from his invoices to me. Do I pay him vat or should he too charge at zero% to me?
Cheers
J
It used to be the case that you reclaimed the VAT after a house was built. You paid VAT on materials etc then got back the total amount of VAT on the build. If that hasn't changed, you should charge VAT on your invoices to the builders. They can claim it back from HMRC...and you will be liable to account for the VAT you should have charged.
just need to know if i pay for vat on a sub contractos invoice to me (who is not charging vat)
As per Mike earlier, the way I read it is anyone and everyone who is VAT registered, including your VAT registered labour only, should be charging, infact must, charge VAT.
It's not untill completion that the project can be deemed VAT Zero.
Althought the project SHOULD be Vat Zero it may not meet the criterior, for example the planning is changed and it becomes Business premises prior to completion.
I’m pretty sure that’s not right.
You only reclaim the vat at the end if you’re a non vat registered house builder or personal self build. I know because I did this myself a couple of years ago.
Otherwise all construction work on new builds is zero vat rated. Nobody charges vat on new builds. Including all sub contractors. I’m sure we never have. You can of course reclaim vat on your materials purchases in the usual way.
Please check this with your accountant though.
Working on a new build , these are my experiences.....
HMRC confirmed to me that i should not charge VAT to the client, this saves the hassle to them of having to deal with a VAT reclaim after building completion. I have therefore not be charging VAT on labour or materials.
I have had zero success convincing subs to NOT charge me VAT, this has caused me some cash flow issues , whilst i reclaim this VAT from HMRC.
The main talking point is what qualifies for zero VAT and what does not. The general rule (which we have been following is.... If you turn the house upside down what falls out does not qualify.... lol
You were actually able to reclaim this vat the subs charged you? Through what mechanism?
I’ve not had to attempt it, but I’m sure my accountant advised it may not be possible to do so. My memory is hazy on that though.
I am subbing to a company on one of these builds, I have been instructed not to charge VAT on Mat' or Lab' even though I am VAT registered, there are certain jobs on the new build that do not qualify for zero VAT which makes it a minefield if you are doing both.
Had similar last summer on a refurb project where they were also adding apartments. Because of the way the additional apartments were added the building works (including electricals) on the new apartments were 5% VAT, all work on the existing apartments was standard rate, and the post building work was also at standard rate.
Most of the VAT registered contractors such as myself of course worked exclusively on the building works for the additional apartments.
Reply to Zero rate vat to sub contractors in the Business Related area at ElectriciansForums.net
Bit of a rant first to explain the situation:- Effing builders again, I knew there was a reason we hardly ever work for them. We've done a few...
I hope this is the right place to post this, please redirect me if not. I've spent quite some time reading the forums, so I apologize if I've...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
Hi all, Been browsing these forums for a while, always great to learn a new way to skin the same cat. Anyway, cut a long story short, was an...
