has anyone pre ordered the new books yet and weres the cheapest place to get them was tempted to order mine on amazon £130 for the reqs,on site guide, gn3 your thoughts chaps
Oh yes, but I am trying to educate people.
Can only do so much.
Well that's a ton up.....made your decision or put your reqqie in?
Are we in agreement that after the 1st of July you should not be installing to the previous version? Regardless whether or not it is designed in December 2014.
But it is not clear about how you should go about installing installations designed prior to 1st July but possibly installed after that date.
It is perfectly clear, and always has been. How could you install or verify an installation to a different Standard than that to which it has been designed?
Its a difficult one to call,
Implementation Dates:
1st January 2015 - The Third amendment to BS 7671:2008, The IET Wiring Regulations, became effective on this date. Following this, contractors have a six month transition period to get up to speed with the changes and can design, install and certify to either the new or previous standard.
1st July 2015 – From this date it is a requirement that all electrical installations designed and periodically inspected comply with the updated regulations. Contractors will be expected to hold a copy of BS 7671:2008, incorporating Amendment 3, for any assessment visit taking place after this date.
1st January 2016 – Regulation 421.1.201 (PROTECTION AGAINST FIRE CAUSED BY ELECTRICAL EQUIPMENT) comes into full effect.
If I am interpreting this correctly during the transition period between the 1st of Jan and the 1st of July you have the choice to either adopt the new regs for design and installation or you can stick with the previous regs (my bold highlighted above). The onus is therefore on you to decide which is either the most convenient or better practice. My feeling would be if there was an significant increased cost involved to meet the new requirements then I would stick to the old regs until I was required to change. Obviously the decision would be discussed with my client. But from experience they tend to go with the cheapest option. After all their first question would be "are the old regs safe to follow?" what would you answer? well of course you would reply with "yes, the new amendments are there to make improvements and are not necessarily related to safety."
Bottom line is it seems yes it would be good practice to follow the new regs where possible, but ultimately until they come into force on 1st July you have the option either way. But it is not clear about how you should go about installing installations designed prior to 1st July but possibly installed after that date. It does note though that if they are periodically tested there after they should comply with the new amended regs. This would imply that you may very well follow the previous regs for the installation but if it is inspected and tested after 1st of July then in will not comply with the new regs. So if you decide to follow the old regs for the design and installation but then did the IC after 1st of July then your new installation does not comply!!!! very confusing indeed!!
My problem with this is that if a periodic report were to be carried out a couple of months later it would be littered with C3 recommendations. I personally would want to avoid this and ammendment 3 will not take much effort to alter a design. Any designer worth their salt would be prepared and any installer signing the work off should be doing what they can to make the changes to the design forced through. If someone gave me a job designed an older version of the regs I would price to install that job to the current standard and make that clear in the quote. We get all our work from repeat custom and my clients would be least than impressed if we just said 'well it was designed that way'.
Also if you say installed a plastic consumer unit in Feb would that be a C2 or a C3 in the next EICR. Also the same with escape routes with cables installed in such a way so they do not fall in the event of a fire.
Why would it be littered with C3s?
First line of the guidance for persons carrying out EICRs in the model forms in bs7671 tells us that you cannot code items purely because the regulations have changed since they were installed.
