A
Andy78
no, ive tried it with through crimps and they split them.
Cheers, I thought that might be an issue. I'll stick with the clunky long arm crimper until I see something better then.
Are the Knipex and Haupa ones pictured in this thread any good for copper lugs, or just really suitable for ferrule ends ? I'm looking for a more compact tool for lugging onto earthing and bonding cables up to 16mm and these look as if they might do.
nah. this is what you need for lugs.Are the Knipex and Haupa ones pictured in this thread any good for copper lugs, or just really suitable for ferrule ends ? I'm looking for a more compact tool for lugging onto earthing and bonding cables up to 16mm and these look as if they might do.
nah these kind are better, they do 10-300mm and easy to usenah. this is what you need for lugs.
Ratchet Crimping Hand Tool 6-50mm² Electrician Pliers Crimper Wire Cable Crimp | eBay
ive got a set of knipex ferrule pliers
cost me £20 and go from 0.25-16mm
my lasy ck set only went upto 2.5 but the knipex go lower lol
sorry i havent tried it on .25 but i havent had a loose one yet (if you need to the very ends are pliers so could always give them a squeeze)Have you tried them on .25?, I do a fair bit on .25/.34 and find some crimpers don't live up to the specs and give me a loose ferrule I can pull the wire out.
a guy that used to work for us had a set and they are great
(not this brand but looks very similar)
we tend to use 0.75 minimum upto 6mm depending on the length of run
we use the same set for cables when these are too smallCheers Tel, those look the business and cheap too. They are a hex crimp die right ?
I've been stuck with one of these type for ages and they are a right pain to use for lugs so small. Very inexact and not really a suitable die shape.
the ones my mate used cost him £50 new on ebayCheers Shanky but I'm just after something small for my domestic work.. those are a bit overkill. I have used those hydraulic type before and they are amazing, the set I used cost a fair bit more than that though.
