Are the Knipex and Haupa ones pictured in this thread any good for copper lugs, or just really suitable for ferrule ends ? I'm looking for a more compact tool for lugging onto earthing and bonding cables up to 16mm and these look as if they might do.
For copper tube lugs you really want something with mechanical advantage/leverage.
nah these kind are better, they do 10-300mm and easy to use
a guy that used to work for us had a set and they are great
(not this brand but looks very similar)
Have you tried them on .25?, I do a fair bit on .25/.34 and find some crimpers don't live up to the specs and give me a loose ferrule I can pull the wire out.
sorry i havent tried it on .25 but i havent had a loose one yet (if you need to the very ends are pliers so could always give them a squeeze)
we tend to use 0.75 minimum upto 6mm depending on the length of run
Cheers Shanky but I'm just after something small for my domestic work.. those are a bit overkill. I have used those hydraulic type before and they are amazing, the set I used cost a fair bit more than that though.
Cheers Tel, those look the business and cheap too. They are a hex crimp die right ?
I've been stuck with one of these type for ages and they are a right pain to use for lugs so small. Very inexact and not really a suitable die shape.
we use the same set for cables when these are too small
99255_P
the ones my mate used cost him £50 new on ebay
there really cheap, everyone should own a set
Place I worked at had a set of these for uninsulated crimps up to 16mm² they worked fine.
markadams,
rapparee,
