Ok I've made that one a sticky.
It is difficult for some members to do work that they would post up for a comp in 5 weeks. If you want to extend the deadline please do so if that is ok with the Trainees. It is your and Rob's comp, long as everyone is ok with extending the entrance date go for it. Staff will help out in any way we can.
OR:-
Keep this one as it stands and I/or another Mentor (may be Sintra) can start another comp up straight afterwards for another prize? This doubles the amount of time for everyone and is fair to all. Your choice mate.
Another idea I had was to have a "Mentors install comp" in the TS? The trainees can be the judges, should be fun :wink:
This would be very interesting :smile:
OR:-
Only if we get to win a few prizes!!!
Re the comp that is running, it makes sense to keep it running now and then if you and another mentor want to come up with the next one that would be great mate.
One of mine.
One of mine.
Show off :rofl:
Nice mate but you've missed the bolts on the front plates :wink:
This is the problem of running install comps, timing on what we are working on at this moment in time. In the next 4 weeks I could only post up a large house/mini mansion rewire. Ok the CU will be good to post up with 20 circuits on a single phase supply, now that has been interesting working out FLC with diversity lol. Or posting up the upstairs landing lighting circuit with 10 x intermediate switches (switch outside of each door as per client instructions).
Alarm install next week but I've given that task to Doody Toody for this comp. I want to do a fire alarm test rig at home, that may be my entry if completed within the comp deadline? So even for full time sparks like me, it is still difficult to post up a picture due to whatever work is on the cards for those weeks the comp is open.
At college today so i took some pics of my comp entry, its still a work in progress and I'm just about to start wiring it up. We manufactured the bends in the trunking and the tray, put set's in the tray and the conduits and also a running coupler in the galv conduit.
First time i'd done any of these myself so it was really enjoyable and hopefully i'll get to do some more in the future!
Pictures are a bit blurry for some reason, think theres something up with my phone camera
That running coupler on the second to last photo is missing a locknut.
Look forward to seeing it wired. Well done.
Hawkeye! It also has no saddles yet... it was the last thing i did today and was running out of time so just screwed it together before i left otherwise it will go missing!
Question is, aside from following your spec sheet. (I'm assuming that's why your using a running coupler on a straight length like that).
Over a length that far, does it need saddles?
Just a note, I guess you won't bother on this temporary installation. If you use a running coupler in a real installation, make sure you use some galvanising spray to re seal the threads and stop them rusting.
Ah that explains the Conduit box without a fixing as well then :biggrin:
I personally wouldn't bother with the saddles but we are working to a drawing and it has either one or two saddles on. We had to fit the boxes first then put the conduit in-between to get a feel for why you would use a running couple and also where to use it in future.
Good tip on the galvanising spray, id never heard of that
I actually did that week before last so not sure whats gone on there! looks like i better buy my own OSG then eh!
**edit**
I know what I've done there now, i coupled the galv conduit box to the single back box first through the knock out then i fixed the back box to the wall and there was a gap of probably 7 or 8mm between the conduit box and the wall so screwing it back would have pulled it out of shape... the saddles will sort it man!
BUMP
So guys we are halfway through the competition and we have a few entries, but we still need more.
Remember there is no pressure and it doesn't have to be a large job, so lets see some more entries please and thank you to those that have already entered.
2015-02-04 10.29.28.jpgNew bit of board work in college :) 2 circuits: 2-way lighting circuit looping through the light and a radial circuit with a fused spur to a light using a 3 amp fuse and 1.0mm^2 T&E to the light through mini pvc trunking
This project was to show the tutors what we have learnt in the past 3 months to make sure we understood the wiring side of things i think the hardest part was light due to having a few cables coming into it.
Next project is a PVC conduit project with a 2way lighting circuit that feeds to 3 lights will post when complete.. just the wiring and testing to do on it :) but college is holding us back cause we are completing the projects too fast haha
Yeah I'm a pretty apprentice so they make us use 12v pretty good job to be honest I've seen 2 Boys in my class try to dismantle there boards while still live they haven't blown the transformer yet though haha
Nice tidy work Kevio, is this your entry for the comp, if so thanks for joining in.
Hi guys I know its a long shot but ill give the competition a try. Im on my first year of proper training and working with a qualified electrician Im also currently doing my level 2 and will be doing my level 3 thats if I pass my level 2 fingers crossed. Anyway we have been working on some new builds. one day were fitting back boxes and pulling cables the next day were second fixing. hear are some pictures of my second fix for you guys to look at and comment
fitting a consumer unit with a qualified electrician watching and advising.. I was sweating....
1. carried out a risk assessment
2. unboxed the consumer unit
3. prepared the unit for wall mounting ensuring I had a secure fixing and the unit was level
4. wired up new board
5. carried out all tests needed
6. Performed little R1+little R2 tests
7. Energized board
8. Finished testing Ze PFC Zs and RCD
9. made sure board was correctly labeled up so that no confusion or error was likely to happen while future work was carried out
fitting a smoke detector
1. carried out a risk assesment
2. unpacked the smoke detector
3. read all instructions
4. located area for fixing
5. had to put wooden lats in ceiling as no decent fixing was available
6. secured the smoke making sure cables were well out the way of screws
7. stripped cables to correct length. well what i was comfortable with
8. wired smoke
9. put smoke back together ensuring it was secure
10. tested smoke
11. put dust sleeve back over the smoke as building and painting were still being carried out
Fitting a single socket
1. carried out a risk assessment ( my mentor is a devil for this but I suppose its better safe than sorry
2. unpacked single socket
3. took screws from the back of the socket
4. stripped cables to desired length
5. wired the socket pulling on each wire to ensure all connections are secure
6. earthed the metal back box ( apparently its not in the regs anymore but mt mentor likes to earth them)
7. pushed the socket flat to the wall then pulled back towards me ensuring nothing has became loose
8. screwed the socket to the wall
9. tested
This is what it is all about, having pride in your work. Well done to all of you, really like it. Top thread GMES and Rob.
Erm??? When are we going to set up a Mentors Comp??? GMES I'll leave that up to you to sort out :wink: Should be fun!?!?
I'm in an office most days now, or if I'm on site im commissioning. So I rarely get to do installation work anymore.
Whilst I might take the odd picture during some of our jobs, I don't tend to take many so it would be hard for me to put install pictures up.
I will try and start to take more in the future.
These photo's are looking good and the competition is warming up nicely.
Keep it up guys because I am already thinking of a couple more competitions for when this finishes, I will be getting my head together with Paulm and other mentors over the next couple of weeks.
My entry:
My entry board for a sparks competition being held on the 18th:
Two circuits; One lighting circuit Switch 1 controlling light 2 and switch 2 controlling light 1 done in 20mm high impact PVC Conduit with the other circuit being a ring final with two single sockets, a joint box and a switced fused spur. Both circuits are connected to a Garage Unit(A small consumer unit basically) due to my board in college being a bit smaller than it should have been I was told to move it down by 150mm.
Forgot to take pictures of the first fix but started by measuring and laying out the back boxes and GU then by shaping and cutting the conduit to size:
90 Degree left bend, 45degree 50mm offset, bending spring used to bend the conduit and the circuit as a whole.(And yes the blue PVC tape was taken off the wires)
It was only my third time bending conduit so these are the practice pieces :lol: all the 90degree bends were too tight and the radius needs to be at least 2.5x the diameter of the conduit.
Then used a cable pull to pull singles through the conduit with a permanent live going from the GU to SW2 then from SW2 to SW1.
The Garage Unit. Which isn't my fault it's so rough, it was the only one the college had :lol:
Then began to run 2.5 and clipping every 30mm, beginning of a run and before/after a bend(pictures taken later since I forgot to)
Once first fix was done I began second fixing starting with the joint box since they're so awkward :| especially so low to the floor.
Now looking at it two of the wires could have being sheathed less so there's around 10mm in the box.
then went onto the Switched fused spur then the switches then lights, sockets and finally with the garage unit
On the GU I was sure to twist and double over the connections for the lighting circuit as it's good practice with one wire going into a terminal that can accept two wires.
Beautiful ain't it? ;) and being sure to leave plenty of wire in case of future alterations(obviously not in this case but in real world installs)
in the case of the Live and Neutral for the ring final I didn't double over since it's two cables into one termination but did for the earth since it's slightly smaller in diameter
Garage Unit wired although it is messy.
Board done.(And I forgot to get a photo with it all done)
Bonus photo!
A shotgun made by one creative classmate complete with working pump action :lol:
This post took quite a while to type out and upload each individual picture also if a mod could be able to rotate any pictures as needed if it isn't too much trouble please?
Big thanks for glenn for being generous enough and putting in the effort for this competition and robb for his donation. Going to have a look at the other entries now, good luck everyone.
I'll rotate the pictures tomorrow after work.... Talking about work, aren't you with a good looking, young & slim electrician in the morning, umm??? I'll show you how to dress up a DB. Also we have a lot of cable clipping to do, may come in handy for a national comp away from the forum???
@GMES. Take a screen shot of the above entry so I can not be accused of changing any pictures etc, only to rotate them (not easy btw, leave that to me lol. Ball ache to be honest,,,, these bloody young trainees asking us to sort out their pictures because they cant do it themselves, I ask you??? Whoops did I say that out loud) Only joking Dody Tody :wink:
Paul pm me your email, I think I have it but just in case.
Also the post is that big I have had to take several shots to get all the pics in.
Eh up :)
Right, this will be familiar to a few, it's a 2365 level 2 board. Here's what I'm aiming for:
I've seen more eloquent ways for fabricating a 90 degree bend, but that's what I'm copying, so that's what I'll do. :)
So I started like this...:
Starting to take shape...:
Time to start cabling it up...:
Alright! :) Out of time. Leave it in the workshop, hopefully they won't need any bits off it for the Monday night class...
Oh. Ah well. Guess that's that, then! :)
I Like it Steve, and yes i recognise the layout!
I know it can't be helped but it must be so annoying coming back after a few days off to find your stuff has been taken apart
Looking good Steve, I think you've put the SWA in better than the demo piece. The bending radius going into the socket looks a bit suspect to me.
Well guys the time as nearly arrived the competition ends tomorrow night and we will have 2 winners for the prizes on offer.
Make sure you tune in tomorrow night for the prize draw at 8pm.
@ all mentors we have some great installs to choose from.
Theres time for a couple more entries yet if anyones been toying with entering but not sure! Go on take a chance, any job no matter how small will do!
can i enter a late entry. this one won prizes in a rats nest competition some years ago.
note: i did not install this. i gave it a C1 on eicr. apart from what you see, the er was no cover whatsoever. still, no loose neutrals. LOL.
********Competition Time***********
Electrical Course Trainees Only
Tags Tags
time
GMES,
Paul.M,
