I'm also somewhat of a DeWalt fanboy, I have several 18V cordless (the older style LiIon, not the latest XR type), as well as the odd corded hammer drill. One thing does annoy me though, the change of battery style a year or two back.
thats my biggest gripe with dewalt.
there old kit was spot on with no issues, now they keep chaning the batteries and there less reliable.
makita tools have used the same 18v battery for years and i dont see that changing
The old ELU stuff was good , it got taken over by Dewalt , I have an 18V one its solid , although its with NiMH batteries , Metabo gear is also very good , but everyday use I use Makita 18 V and Makita roto stop 230v drill
And what's your views on getting the brushless model? Or does it not make much difference
the brushless models run cooler, ive got a Makita brushless and it runs cooler and for longer than the older version on the same batteries (body only tool so they were not new batteries that i tested it with)
its rare i have to charge batteries in a day now unless im drilling a lot of 16mm holes with my sds.
the brushless drills from all the manufacturer's should run cooler because there isnt friction from the carbon brushes for a start
Makita all the way for me. Great array of tools, same battery, which you can get in 3, 4 and now 5Ah versions.
I burnt out a Combi drill cutting massive holes in I-beam webs, but I worked the nuts off the poor thing, and it still lasted 3 years bless it.
Ordered another as soon as I smelt burning plastic.
the good thing about the new ones is they cut out when they get too warm, let them cool and there fine.
i really abused my old one, drilled over 20 x 20mm holes in a glandplate in an outside panel.
Don't rule out hitachi.
They are utter rubbish, I was issued one of their SDS drills by a previous employer, it had to be replaced under warranty every 4/5 months as they kept failing in normal use. We had similar trouble with 2 cordless drills of theirs too.
When I started my apprenticeship my mentor had a spit 322 SDS which was a few years old then and was still going strong 8 years later despite serious abuse. That's the kind of reliability you want from a drill!
