S
sime27
Hi all
I need to put the location of electrical accessories on to a cad format drawing sent to me by my builder.
What's the best straight forward and affordable software.
Autocad I'm guessing is best but expensive.
Pre thanks all
Re: Cad doftware
autocad has many different versions so be careful you select the right version, there are free alternatives but you might end up with errors using them
Re: Cad doftware
Which autocad would you suggest? And do you know of any good free alternatives
Re: Cad doftware
The drawings off the builder as internal layout I just need to add electrical accessories
Autocad LT is fine for building drawings, latest version will back date to older versions. Cost around £800
Anyone recommend a alternative cad software or advice on where I could get my hands on autocad
Auto Cad only way...If your stuck I can convert to WMF (for word) of PDF if this would help.
QCAD hasnt been mentioned.
I run it here on Linux - excellent, as with all CAD programs, it isnt easy to use at first, but when you get the idea behind it, it is great.
£25ish.
Reads and writes to most CAD formats, and keeps the formatting correct. It has a good user support, with bug fixes fixed quickly - the beauty of open source.
http://www.qcad.org/
