O
Octopus
Murdoch;
That is the issue when so many say two RCDs in the same circuit is not a good idea.
I don't see this as two RCDs in the same circuit.
I wouldn't remove the one in the house main consumer unit as this RCD is the one giving additional protection to the circuit supplying the garage.
And it's my understanding that the other RCD in the garage is giving additional protection to the garage circuits.
I think I see where the issue is with these so called garage C.U. The lack of a dual pool isolating switch. This would then separate both RCDs.
But please, do correct me if I am wrong.
One is always learning and I would just like to give my friend the best correct advice.
Thank you.
Albert
Just remember don't put 2 x 30mA RCD's on the same "circuits". Its that simple.
