M
Marc Lajevardi
thanks for the useful replies everybody, there are some things i would have never thought of! EG a pot noodle ha! I appreciate all the help!!
this is the only stanley worth having
ive got stanley, haulfators etc but always go back to these
yeah that one, strange you cant see the image
Wouldn't expect a first year to be isolating anything, best thing to bring is a bit of enthusiasm! If an apprentice is keen i don't mind picking them up and lending them some of my kit! Pair of cutters, some screwdrivers, hacksaw, set square, pliers and a tape measure.
3/8 is better, you can get the 17mm in unistrut then for doing framworksI think it's a good idea to get an apprentice locking off and testing circuits, "supervised" from the early stages, always did it with the lads working with me, it breeds good habits and also shows a bit about the apprentice ie if their first thought is to get the lock off kit out ,then Imo it's no bad thing!
The majority of installation electricians I've worked alongside, never owned locks and would tape over a mcb, these lads always had tales to tell about the shocks they'd received!
Whereas I know for a fact the lads who were brought up in a culture of safe isolation very rarely get caught out!
As for tools for a first year ,domestic a good club hammer wickes do a good one which doesn't have an anvil on the end of a short stick,
Industrial a good 1/2" socket set for the smaller stuff.
yes, the blade is locked till you press the button at the back to unlock it (so its at 45o) then hold the little one near the blade.Is the above better than the Stanley FaxMax? The blades on mine keep on slipping out :shout:
i prefer folding to sliding blades because your less likely to stab yourself
if you have the knife straight as to cut something you cant get the blade out on the irwinCheers, never stabbed myself though? A few old scars on the left hand from being young and stupid! I have drilled my left leg with a 4mm drill bit down to the bone once, but that is another story.
If anyone has a FatMax Stanley knife may I ask, dose the blade fall out whilst doing a long cut, eg floor board tongue & grove/plaster board? The quick change over of blades is a great idea but when using the knife the mechanical parts inside that should hold the blade in place fails? May try an Irwin next.
