Have you never continuity tested the chain once it's up? Dont they teach Electrical Trainee's nuffin' these days?;)
Got plastic lamp holders says class 1 on the box so that should be the complete fitting not just the top !
Should it? I haven't got copies of the manufacturing standards which set the rules about this. I assume you have?
This would depend very much on what the "class1" description described or alluded to... The addition or omission of a single "s",can alter the actual legal definition,whatever the manufacturing standards are,of the specific place in the world,where this is from.
Surely if a light fitting is 'class 1' then it would apply to the whole fitting, not just certain parts of it? Daz
No mate more metal in that ,wouldnt be worried about the earthing if it was plastic
The Chinese make up the rules as they go along - its probably earthed at the top rose where the connections are then double insulated through the rest
I think class I can have double insulated parts. Think metal light switch with metal rocker - the plate is earthed but the rocker is double insulated and has no earth connection. In the case of your light I think the chain would count as 'casual or fortuitous contact' with the earthed parts.
Caveat: I couldn't see the pic as B & Qs website was down.
