Search the forum,
Discuss How can this be a Class 1 fitting in the UK Electrical Forum area at ElectriciansForums.net
Got plastic lamp holders says class 1 on the box so that should be the complete fitting not just the top !
This would depend very much on what the "class1" description described or alluded to... The addition or omission of a single "s",can alter the actual legal definition,whatever the manufacturing standards are,of the specific place in the world,where this is from.
Should it? I haven't got copies of the manufacturing standards which set the rules about this. I assume you have?
Surely if a light fitting is 'class 1' then it would apply to the whole fitting, not just certain parts of it? Daz
The Chinese make up the rules as they go along - its probably earthed at the top rose where the connections are then double insulated through the rest
I think class I can have double insulated parts. Think metal light switch with metal rocker - the plate is earthed but the rocker is double insulated and has no earth connection. In the case of your light I think the chain would count as 'casual or fortuitous contact' with the earthed parts.
Caveat: I couldn't see the pic as B & Qs website was down.
Reply to How can this be a Class 1 fitting in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
The following light fitting from Dumelm takes GU10 but states "Dimmable No" but I can't see why with the correct dimmer switch and dimmable GU10...
Hi All I’m presuming a standard pendant is a class 2 fitting as the earth terminals are not needed as it’s a plastic fitting and it only has an...
7K
Hi all, Got an antique light fitting that for some reason she wants putting up (can't say I love it haha) however it didn't come with any...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
