T
Tidy Max
:90:
So i have been doing a rewire on a 1600s property. Lovely customers but the job is dragging on abit as they are also having building work done.
Text of the builder asking if he can cut a redundant telephone cable in a bedroom to which i said yes.
Text of the customer that night saying the builder has cut their temporary internet cable so they have no BB could i solve it.
Spent a day second fixing today and remembered about the internet just as i was packin up cables. Connected reconnected the chopped cable... no BB.
Went to the master socket to find cables have been chopped out... reconnect cables, no BB.
Go out to the front of the property and see this.......
Which leads us to the next problem that the front of the property is being K rendered tomorrow.
Any ideas? The customer isn't overly pleased and i have had the problem basically dumped on me. I am assuming a phonecall to BT (the correct course of action) is going to result in a hefty charge (minimum £120 callout iirc?).
if you lucky the line will be still live (measure with volt meter, should be some 30-40 volts on it) , install some weatherproof junction box, run bit of cat5/phone cable to wherever needed and patch up the cable
if you are not lucky then the line get shorted and got disconnected in the local exchange box, then is a phonecall to bt and ££ to pay.
Cat 5 won't do outside though Bud, it will need to be external quality cable or it will deteriate very quickly, probably 2 winters only and it will be knackered.
Cheers chaps. That was my poa for tomorrow morning, just trying to gauge what you lot would do also. The cable seems to be surprisingly large 2 core which i wasn't expecting. It looks about 1/1.5mm (large for telephone cable) as i know mine at home is an 8 core straight from the telegraph pole.
Ta for the replies
I wouldn't put cat5 outside MDJ, i will be going to CEF in the morning and having a route through the stores to see what i can find. Possibly a rubberised flex? I have done a fair bit of network cabling etc but this incoming phoneline has no twists and is literally just 2 core?
Bloody hell i have got a TLC delivery arriving tomorrow aswell! Thanks for the advice chaps much appreciated
Put the customer back on with a bit of cat5, then replace with the dropwire 10 from ebay. Get some gell filled scotchlocks from a telecom supplier to make it look like a pucker job.
