I'm also with Dave, I just think that you're being unnecessarily cautious by trying to cater for a scenario that should never reasonably happen. Just my thinking and others may disagree.
And I would think if it is a water feature it will be clearly visible or obvious that it has an electrical supply.
It is also reasonable to expect anyone doing so to make efforts to identify the presence and location of any buried services.
Some of the landscape gardeners I have met are not that smart!!!!
It seems to me that this one is down to an indivual sparks opinion!
This old chestnut. The regs are conspicuous by the lack of "proper" recommendations and it's about time this was sorted.
I have run swa under flag stones, and will do it again.
the last landscaper I encountered on a job asked why I was wasting the clients money using swa rather than flex!
Could I suggest trunking ? How many likes will I get for this ?
Not as many as if you'd suggested ducting.
There are a few good reasons for putting underground cables in ducting: Less likely to damage cable if hit by a spade. Less likelihood of cable damage due to stony backfill. Easy to add or change cables in the future. Cable can be pulled in after groundworks have finished so less chance of damage by other trades.
