A
Alessandro
Hello!
This is my first thread in this section of the forums. I'm relatively stuck with my design assignment, I was given drawings of a highways depot and I have to design the whole installation, show wiring systems, divide the installation into final circuits and do all the calcs. I'm okay with the purely theoretical part of the assignment, calculating things etc, but I have a problem with the initial part, where I have to show wiring systems on the drawings and explain the reason for my choices. The fact is that I have never installed something like this, and I don't know if what I have in mind can be done.
The building is divided into 2 sections, a workshop and the offices. "The office section is outer fairfaced brick with inner leaf blockwork. All inner walls are plaster finish. Ceilings are suspended 600 x 600 mm tiles on grid 2400 mm above finished floor level. Floors are carpet throughout with exception of the toilets, restroom and stores which have an anti-slip sealed covering."
So I have ground foor and first floor, power and lighting, 3-phase supply for the lift, one oven. My questions are:
1) Someone in college said to me that I should fix cable baskets on the wall inside the suspended ceiling area, and put all the cables there. Does this make sense? It sounds like you would spend thousands of pounds just to buy and install cable baskets, isn't this crazy?
2) Obviously the cable basket will have to go through walls. Can this be done without compromising the fire resistance integrity of the building? How? I can see how to do it with trunking, but not with baskets.
3) I was going to use PVC conduit in the offices to connect sockets and switches. How should I take the cables from the cable basket in the ceiling area to the PVC conduit? If I have the cable basket on one side of the room and I have to install a socket on the opposite side of the room, and the wall-to-wall distance is 4.5 metres, should I just lay the cable on top of the suspended ceiling for 4.5 metres or maybe clip the cable to the concrete ceiling? Or install cable baskets on the whole internal perimeter of the room just for one socket? But my teacher said I should not clip anything on the concrete ceiling or put the cables on the suspended ceiling, so....?
4) Should I put single core PVC insulated (not sheathed) cables directly on the baskets for power and lighting? Or do I need multi-core sheathed cables for better mechanical protection? But I'm sure it is better to have non sheathed single core cables for the PVC conduit, which is where all these cables are eventually going.
5) For the oven and the 3-phase lift supply, can I use multi-core PVC sheathed cables? Or SWA cables? Can I just lay them with the other cables on the basket?
6) When I do the lighting, I would probably go from one ceiling rose to the next rose directly, but then all the lighting cables would simply lay on top of the suspended ceiling. Do I have to clip the cables to something or should I leave the cables on the suspended ceiling?
How would you normally do all these things?
Then obviously PVC conduit or fixing are not suitable, but I'll double check for suspended ceilings and wiring inside them. I'll definitely add this consideration to my assignment though, precious and vital advice.
