Discuss Adding a meter in the Electricians' Talk area at ElectriciansForums.net
Hi Guys,
Bit of advice please. I've been asked to quote to add a meter to a 12 way board in a warehouse. The job is pretty strait forward but am i right in saying, by doing this i will need to test the 12 way board after
Hi Guys,
What sort of meter? Presumably it'll be connected via CT's? If so then use split CT's you can retrofit and the only connections you make will be for the voltage connection so very little to test.
Hi Guys,
What sort of meter? and what will it be metering?
Reply to Adding a meter in the Electricians' Talk area at ElectriciansForums.net
Morning all, Really hoping to get some advice / confirm what a few of us are thinking about a job in the future. Back ground - We have to swap...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
I have an new set of circs here... Landlord in Cyprus EICR needed in empty flat. No credit on meter. Need power for Ze (TNCS) and RCD test at...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
