Currently reading:
Adding a meter
Discuss Adding a meter in the Electricians' Talk area at ElectriciansForums.net
Hi Guys,
Bit of advice please. I've been asked to quote to add a meter to a 12 way board in a warehouse. The job is pretty strait forward but am i right in saying, by doing this i will need to test the 12 way board after
Hi Guys,
What sort of meter? Presumably it'll be connected via CT's? If so then use split CT's you can retrofit and the only connections you make will be for the voltage connection so very little to test.
Hi Guys,
What sort of meter? and what will it be metering?
Reply to Adding a meter in the Electricians' Talk area at ElectriciansForums.net
