H
hightower
Bit of a strange one.
2 pendants that (apparently) used to work as such until one of the switches was rewired by a friend of theirs:
Switch 1, 2 gang
Switch 2, 1 gang
Switch 2 and one of the gangs of Switch 1 work in tandem to create 2-way lighting. Either switch turns BOTH lights on and off, as standard two way. The remaining gang on Switch 1 turns ONE of the lights on and off independently.
Now, I think she's getting her wires crossed somewhere, I'm going to draw it out when I get in later on but I can't see it working from what I can map out in my mind. I think maybe 1 of the lights worked on a 1-way switch, and the other light worked on a 2-way switch. This is in a living room, so I wonder if it's an old dining room knocked through.
Just thought I'd ask for thoughts before I get in and have chance to draw it out. At both switches there are 5 cores - a 3 core and a 2 core each. My guess is Switch 2 has the 2 core as the feed and the 3 core as the strappers, going to the 3 core at switch 1, and feeding one light. Then the remaining 2 core at switch 1 will be a switch drop for the other light.
Will get a chance to test it properly sometime and figure out what goes where, but can't stop thinking about it for now.
hmm. don't take a customer/ friend/relations assessment of the situ. wait till you see it and then make your own assessment of what does what and if, and then suss it out.
Does it sound like anything you've heard of though?
nope.methinks they're confused.
Switch 1, 2 gang
Switch 2, 1 gang
DIY Dave been on the plot??
I'd guess it was set up so that the 2 way switching (1 gang plus gang 1) always turned 1 light ON , but would turn both lights OFF depending on the position of gang 2.
It should be pretty straightforward once you're there looking at it.
It sounds like the feeds are looped at the roses, each 2 core being a feed and switched live, one at each plate, which will become apparent once you open them up.
I'm insinuating that "someone" has took off the light switch for replacement and went "errrr F***... lucky dip time"
Well yes, I quite agree. But if you're insinuating it was me, well let me tell you that I like magic but messing with a system I haven't even seen is beyond even me.
Without a relay or a double pole switch (in two way!) then you would not be able to have one light controlled by two switches, one of which also controls another light.
if you were trying to do this every time the single light was switched on it would back feed the other light as well.
You could have an arrangement whereby both lights were on the two way switching and one of the lights had another switch in its switched feed so that if both were on this one could be turned off, however it would only be able to be on if the two way switching were on.
You can make the override work the other way, so that switch 1 gang 2 forces its light on even if the 2-way is off, by teeing its L1 into the SL from the 2-way, feeding L2 with permanent live, and running the light from the common. I.e. it selects between whatever the 2-way is doing and 'on', without backfeeding the 2-way SL.
Or, if you want to be really perverse, you could have a kind of Y-shaped 2-way, where the PL goes in at the common of the single gang S2, two strappers run to the L1 & L2 of both gangs of S1, and the two lights run from the two commons. Whatever the state of S2, you have individual control of the two lights from S1. And if the two gangs of S1 are in the same position you have combined control from S2. The problem is that when you want to control from S1 and the two gangs of S2 are in different positions, S1 will turn one light off and the other on.
Lucien, I've had far too much to drink to take that in. ..... but first thing tomorrow I'll be back to re read
