H
hightower
Bit of a strange one.
2 pendants that (apparently) used to work as such until one of the switches was rewired by a friend of theirs:
Switch 1, 2 gang
Switch 2, 1 gang
Switch 2 and one of the gangs of Switch 1 work in tandem to create 2-way lighting. Either switch turns BOTH lights on and off, as standard two way. The remaining gang on Switch 1 turns ONE of the lights on and off independently.
Now, I think she's getting her wires crossed somewhere, I'm going to draw it out when I get in later on but I can't see it working from what I can map out in my mind. I think maybe 1 of the lights worked on a 1-way switch, and the other light worked on a 2-way switch. This is in a living room, so I wonder if it's an old dining room knocked through.
Just thought I'd ask for thoughts before I get in and have chance to draw it out. At both switches there are 5 cores - a 3 core and a 2 core each. My guess is Switch 2 has the 2 core as the feed and the 3 core as the strappers, going to the 3 core at switch 1, and feeding one light. Then the remaining 2 core at switch 1 will be a switch drop for the other light.
Will get a chance to test it properly sometime and figure out what goes where, but can't stop thinking about it for now.
Switch 1, 2 gang
Switch 2, 1 gang
