Hi soulsurfer: Yes mate the timbers that go up either side of the staircase are called the strings.
When we used to have them routed into the strings, it was always done by the team carpenter but string lighting does look the part.
Whichever way you decide mate, I'd love to see pics of the finished job.
Of course & thanks for the help
Can't find the pic, but I have an LED tape up the side of my stairs - the strip cant be seen because of the overhanging wood bit.
Activated on outdoor photocell - gives light for the kids at night if they need the loo (downstairs bathroom)
edit - won't work on your stairs as no overhanging wood bit
No problem the pic I posted is a generic google affair not the stairs I'm dealing with but I can get a Chippy to make it have an overhang ! ;)
Pics
@Doomed how did you wire the mouse into the circuit? :D
You can pull the stair string off, fit the lights then refit the string. Might make it easier. They work great with 2 way pir as a night light.
If you go with the led strip method I'd put the strip into an extrusion, it looks more integrated into the stairs in my opinion.
How are you going to pull the strings off ?, you'd need to totally dismantle the staircase. The treads & often risers are let into the strings on either side.
Or are you thinking of the capping ? The bit hiding the LED's in Doomed's pictures.
