OP
Squid
Just wonder if its been derated at some stage, I may also be talking ball cocks.I'm no expert on motors but surely the 300Hz motor isn't designed for direct connectionn to 50Hz supply?
Discuss Advice Needed - CNC Machine Tripping in the UK Electrical Forum area at ElectriciansForums.net
The thing is when its plugged in to a standard socket elsewhere (the one with the dodgy CSU) it works fine, I am trying to get some more info as we speak.If he is plugging this to a 13A socket I can only assume the machine has a phase / frequency converter fitted which is an expensive bit of kit. This may also offer variable speed drive of the motor by changing the frequency. I wouldn't mind seeing the inside of the control enclosure. According the motor plate it is only a year old and maybe he should refer to the manufacturer with regards to the rcd tripping.
Not sure but looking at the bodges I doubt it.On the second board is the mcb for the circuit he is plugging in to defititely rcd protected?
Anyways,
My architect based down in Limehouse renting work space in a building bought himself a CNC machine and off course when he powers it up it trips the RCCB so I am looking to get some advice from the knowledgeable sparks on here so that I can pass the advice on to save him being ripped off.
Below I have pasted in a photo of his board as well as the label off the motor on the CNC machine (its not 3 phase BTW) he also tested the machine out in one oh hie "neighbours" work spaces and it works fine and nothing trips but as you will see from the photo the install is criminal and I have never seen a bodge like it.
Any help appreciated.
Reply to Advice Needed - CNC Machine Tripping in the UK Electrical Forum area at ElectriciansForums.net
