Don't stress and be meticulous with checking everything. Like others have mentioned could be lack of contact to the busbar. RCBO broken. At this point i bet the client is sniffing around. Tell him or Her to go away. The amount of people I've had to do this too. Who peer over your shoulder and comment how easy electrical work is. Good luck
UPDATE- thanks for the response everyone, the problem is sorted.
I took the rcbo for the lights out and the busbar was discoloured. Cleaned it up, refitted it, problem solved. ( even tgough it was showing 230v on tbe bottom screw it must have been too poor of a connection).
RCBO for cooker circuit was completely replaced as the same process didnt work.
Who knows how it broke
good man ,now you would thank the people like that helped .they do at the Oscars with likes !
like the oscars? you mean sloppy hugs and pretend cheek kisses with about as much sincerity or emotion as a kipper?
