J
joel89
hi all I am fitting a rotatory isolator in series with the panel door mounted isolator on a star delta radiac saw.
The current main isolator located near the DB has Red, Yellow, Blue coming in. Going out on Brown across red Grey across yellow and black across blue. The cable goes to the panel isolator grey l1, brown l2, black l3. The cable between the main isolator and panel is where I am breaking in, in series to be able to use 2 isolators. I am confused on how I should connect the phasing into the new isolator so I don't reverse anything. As star delta are a nightmare
