On a job today to work out plans and discuss options with customer for a series of down lights in dining room and kitchen. went to do a few tests to check existing cables were okay and I open up the CU to discover lighting circuit installed as a ring using 2.5 T&E. This is on just the downstairs light circuit, the upstairs is conventional radial in 1.5mm
i suspect a DIY'er has gone to work a few years back as its old colour cables, the CU is poorly installed with cables all over the place inside poorly terminated. Couple bought the house in 1999 and no significant work has been done since so looks Pre part P DIY'er nonsense.
Never actually come across it myself before, only heard about it.
Question is why install it as a ring though??
Beyond this instance using 2.5mm which suggests its all somebody had to hand and didn't want to go get some 1 or 1.5 i see no real point. it means you have to run the cable back to the CU from the last point on the circuit. termination is a bit trickier on the space side too.
Not aware of any regulation that it violates though..
Anybody else come across this or aware of any regs it violates?
On the other hand I once found a power ring with the respective ends terminated into individual 15a rewirable fuses.
