Discuss My First Van Break In...... in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
loulew
So I've just experienced my first van break in. Happened an hour ago, broad daylight with the van parked at the front of site I'm working on.
Only managed to get a drill though as a cyclist disturbed them.
How's everyone else's day?
Thanks, no just a bit of damage where they've jammed a screwdriver in the drivers door lock. Took them about 15 seconds from getting out of their car to driving off again apparently.
When I'm working, I make sure every time I get something out of my van, I double lock it afterwards. Unfortunately, the double locking has stopped working from prolonged use! Might just leave one of these in there:
I was thinking more along the lines of a mad max style self-destruct but that may just be the anger talking. Yeah, she was in the right place at the right time. They could have got away with a lot more if she hadn't gone past.
need to do mine also. Garrison seems a decent price for slamlocks. only need the one. going to fit bolts to the inside of tailgate, so can only be opened from inside when these are locked in.
I like your thinking. i saw a van in my local screwfix carpark the other week, the guy had welded what looked like a piece of upside down guttering above the side door so that when unlocked it still slides out the way but by over hanging the door it stops scally wags doing this new trick of pushing in the side door and pulling the top down like a tin of fish... with his upside down guttering they cant get their hands up inside to pull, very simple but highly effective... I asked him to show me it and its literally just curved metal sheet approx 5mm thick welded onto the van with a plate on the front end and then grinded to a smooth edge. for safety reasons he has a piece of foam on it.
After my van got broken into few months back I went a bit ott and now have slam locks and extra locks i have bolted on. I also had my side door welded shut and invested in a nice van vault box. as I cant afford another financial hit, the police and insurers dont give a damn... I was thinking of putting extra metal or anti cut security cables in by the metal panels behind the racking to stop the little idiots cutting through the body to reach tools.
Think I will definitely invest in some slam-locks. I like the idea of the anti-cut cable behind the racking too. My MFT is usually right next to the back door in the racking along with my drill so that would have been taken today. Luckily I have literally sent it off this morning for calibration. I have my DI Assesment next week so glad I didn't lose that.
Thanks Buzz, i like the look of the Garrison locks. And they're not too badly priced either. Did you fit them yourself or get a company to do them?
why do you think the pikeys always buy transits? first thing they do is work out how to get in them without a key.
@loulew Another thing you might want to consider is maybe putting secondary doors behind the main vehicle doors so that when you open the original doors you then have a 2nd set to unlock, you can make them easily enough, with metal plate and a frame just hire a welder for the day. you can get them fitted. that way if somebody peels your doors open or forces the lock, they have to spend even more time trying to cut through couple mm thick plate metal... its like a cage that sits in the back. would certainly stop any but the most determined thief....
something like on this link but choose solid plate rather then mesh...
Van interior cages - Yorkshire | ProtectAVan - https://www.protectavanltd.co.uk/van-security-cages-465-c.asp
When i replace my van sometime next year i will certainly be giving the idea of an internal cage serious thought as it will stop the idiots in their tracks, and can always be removed if i sell the van.
I was actually thinking about something like this too. Could be a nice little project too, always wanted to learn a bit of welding! But then where where does it stop? Before i know it i'll end up with an armoured van!
There are plenty of MOD surplus armoured vehicles on the market, they are disposing of tonnes of stuff now Afghanistan is done with... The MOD auctions aren't a bad place if you are looking for a decent serviced vehicle...
HandySparks has just upgraded the locks in his van - I'm sure he'll provide details later!
Transit Custom
I've just replaced the driver's door lock on my Transit Custom with this:
Sussex Installations FOR3-RL-SR REP LOCK FORD CUSTOM 2013 ONWARDS - Replocks - Sussex - https://www.sussexinstallations.co.uk/products/replocks/sussex-installations-forc-l3-rep-lock-ford-custom-transit-custom-transit-custom-2013-on.html
They'll do it for you (at extra cost), but I decided to give it a go. Went fine, but it's the sort of job that takes an hour or more the first time. I could do a second one in 15 minutes.
The issue with the transit (and probably many others) is that if you can unlock the driver's door, which is the only external lock on the van, it can trigger the other doors to unlock too. So changing it to one that's harder to force and harder to pick is worth doing. I also cut the wire that connects the door lock to the central locking control, so even if the lock is forced, it still won't unlock the load compartment. You can now only unlock the rear with the correct remote key. There is a software update for some vans to do this, but I wasn't going to wait for it to be done at the next service.
See FordEtis home page - http://www.etis.ford.com under outstanding field service actions.
Select Preferences/English/UK to get it to recognise your registration number.
My next task is to disable/lock the OBD port, which can be used to program a key to turn off the standard immobiliser and alarm.
Loads of info on the Ford Transit Forum:
Ford Transit Forum • View topic - How to remove drivers door panel to replace lock with hykee - http://fordtransit.org/forum/viewtopic.php?f=65&t=177300
Ford Transit Forum • View topic - Additional tips for changing to Hykee lock on your Custom - http://fordtransit.org/forum/viewtopic.php?f=65&t=178850
Ford Transit Forum • View topic - Failed break in. How far could they have got? - http://fordtransit.org/forum/viewtopic.php?f=65&t=178619
Ford Transit Forum • View topic - etis security update - http://fordtransit.org/forum/viewtopic.php?f=65&t=181381
Ford Transit Forum • View topic - Make your Custom a lot more secure for free! - http://fordtransit.org/forum/viewtopic.php?f=65&t=178018
Ford Transit Forum • Login - http://fordtransit.org/forum/viewtopic.php?f=18&t=181074
Ford Transit Forum • View topic - security - http://fordtransit.org/forum/viewtopic.php?f=65&t=181087
Ford Transit Forum • View topic - Door lock removal. - http://fordtransit.org/forum/viewtopic.php?f=65&t=171142
Couple of videos from Sussex Installations explaining the problems and solutions:
i'll be fitting a Garrison slam lock to the side loading door. 2 bolts on the inside of the tailgate. these can only be opened from inside which is no big deal. also considering disabling the driver's door lock from the central locking, as suggested by Handy Spark.
I'll definitely be looking in to disabling the drivers lock from the central locking. But the bolt idea wont be any good for me, i'm not always able to climb through to be able to undo them. But it's a very good idea!
Reply to My First Van Break In...... in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Hi all. In a bit of a situation which is starting to cause a fair bit of stress and figured maybe asking some silly questions here may help to...
Hi everyone :) my first post here. Quick background I'm a newly qualified installer of somewhat advanced years whose just starting out in the...
Hello and Happy New Year. It's not starting too well for me, excuse pun. Since Friday December 16th, The 2.4l Duratorq diesel won't start...
