Sorry I sound uneducated lol, what do you mean a part p scheme? Do I need to do the part p course even though I'm a gold card electrician ?
No you don't, just pass the assessment of the scheme you join.
You can download part P, and all the approved documents of the building regs, here. It contains the scope of what work is notifiable and what is not.
Approved Documents | Planning Portal - https://www.planningportal.co.uk/info/200135/approved_documents
Part P is just a document, not a course or a qualification. So called part P courses are just a scam to feed off the confusion that surrounds a blinding simple concept.
1. Certain works in dwellings require notification to BC by law, the part P document I gave a link to lists the work requiring notification.
2. You can notify as an individual but it'll empty your wallet, and is not viable if you are a contractor with regular jobs requiring notification.
3. You can join a scheme which will enable you to notify at minimal cost, typically a few pounds a job. You will pay an annual fee to that scheme.
4. Contact the scheme of your choice to discuss entry qualifications they require.
The way around it that you are looking for doesn't exist unless you choose to ignore the law. Many do.
basically, new circuits, new CUs, and any work in a bathroom are notifiable under part pee. for minor jobs, no notification is needed. just a cert.
Have a read of the part P document.
Electrical safety: Approved Document P - GOV.UK - https://www.gov.uk/government/publications/electrical-safety-approved-document-p
It is a legal requirement that work carried out in dwellings complies with Bs 7671, and that certain works in dwellings are notified to building control. The only cost effective way of notifying is through one of the schemes.
Most work will require an EIC or MW cert issued to the customer, and you will then notify building control (if required) through your scheme.
The term 'signing off' is often used but is rather misleading.
No it is not a legal requirement.
There is a legal requirement for the work conducted to be safe, compliance with BS7671 would be deemed as being safe.
When i made the jump to become self employed i contacted my LABC as i am not currently a member of any scheme. They were very helpful, which surprised me, basically as others have mentioned not all work is notifiable although all work should be tested in accordance with BD7671. I had to provide evidence of my qualifications to my LABC and am now on there register as a competant person. If i do any work that is notifiable i have to fill in a form and send it to them prior to work starting, along with a fee of £85. This cost isnt to bad on a larger job where it can be lost for example a rewire, but obviously smaller jobs it would pay to be part of a scheme.
