doesnt DNO basically insist on you becoming the BNO and installing a RyefeildWhy ryefield board and not control panel.?
and 1 point of isolation- hence the 200a switch before the Ryefeild
Discuss kva of new supply- query in the UK Electrical Forum area at ElectriciansForums.net
guessing he meant dis board? and surely discrimination wouldnt be correct if using a mcb as apposed to a 1361Control panel?
Perhaps he means using mccb’s?
Panel board.Yes i did. I call it a control panel with mccb but may not be the correct grammer.
Have a feeling they pretty much insist on a ryefeild setup or possibly a lucyYes i did. I call it a control panel with mccb but may not be the correct grammer.
Reply to kva of new supply- query in the UK Electrical Forum area at ElectriciansForums.net
