Been holed up with trageminal neuralgia apparently the worse pain known also referred to as the suicide pain, thank you to my docs for making it to the surgery today so your post gave me a right chuckleOr have you been snowed in, and got no beer![]()
Hi Sparky,Most of them, so long as the back box is deep enough.
Edit:-
40mm minimum to give yourself some wiggle room with the conductors.
Not sure about conduit connections... if you're talking conduit you'll probably have to carefully cut holes in the patress box. If you're actually meaning trunking, then the entry points will be plenty big enough. Some boxes even include cable clamps.
To avoid breaking the plastic boxes, cut the entry points with a junior hacksaw first, then break them out and clean up the edges with a file to prevent damage to the cable.
Further edit:-
And as it's a new circuit, it goes without saying it will need properly testing, an EIC and a building control notification. Depending on the size of the load, you may also want to consider the loading etc. in the consumer unit.
This sounds like an ideal option, I will have a look at my local branch.most wholesalers sell pvc boxes that have a pop out bit that takes a collar for the trunking so it fits nice and neat
Hi Wilko,Hi GK - you might like to get yourself updated to Trainee, which is you if I recall correctly![]()
LOL I meant trunking and not conduit and I will be using 6mm T&E. IS the self addesive trunking really that bad??????? If so how do you guys attache it, a few screws though the trunking?What size cable is he using ? Must be a big loading on this cooker !!![]()
Been holed up with trageminal neuralgia apparently the worse pain known also referred to as the suicide pain, thank you to my docs for making it to the surgery today so your post gave me a right chuckle![]()
