Hi guys, new to this so appologies if I'm posting in the wrong place.
I was just wondering if any of you have come across a standard 1 gang light switch with a neon, and if so, where to get one from?
I've been scouting around but haven't found one as of yet.
My elderly neighbour has two separate attic spaces. He tells me his wife often goes up and when she comes down and closes up the hatch, she usually forgets to turn the lights off, so they often stay on for days at a time.
He's asked if I could possibly find switches for him with neons as a little reminder to turn the lights off.
https://www.google.co.uk/search?q=1...x-b&gfe_rd=cr&dcr=0&ei=YoG6WrC2IrHS8AeyzJvoBw
The 20Amp would suit your needs, not sure if you can get a normal 6A lighting switch with a neon, some of the others my have some knowledge of them.
Like those, Marconi. Wonder why the illuminated one is marginally cheaper...
Only worry is if a less able person is in the loft and the lights go out...have to fumble way to top of a ladder in the dark...
I once had to work in a loft which had a mechanical run-back timer for the light switch, it could be set between 1 and 9 hours do you could turn it on at the start of the day and it stayed on for the whole day.
But then that was the somewhat large loft of the national maritime museum.
If I had the choice...
I'd go with a Butler, tbh...
he could go round every evening and switch everything off!
and could double as a chauffer...pick me up from the pub...
really liking this idea!
Forget remote switching...just tell George!
Timer switch could be an issue as I know they have a little gym setup kind of thing in the loft.
Long period timer switch would be a more likely option, but obviously price pending.
I highly doubt he wants to spend much on such a small issue.
Apologies if I come across thick now, (I'm still very much learning the trade) but if were to install a PIR switch in the loft, would I have to make it 2 way with the existing switch on the landing or would it just be fed direct from the light?
