I have the sparky wall chaser. FYI it’s very heavy and unwieldy. So far I’ve only tried to use it on an uneven stone wall but gave up due to weight. Easier to use smaller grinder. Despite mask and goggles still washing grit out of my eyes :confused:
Did some chasing the other week. Couldn’t face using wall chaser or grinder. Just pin drilled. Joined the dots with masonry attachment on mult-tool and knocked out with SDS chisel. Was a fairly soft block wall though :p
for small chases in plaster i use multitool with oldish blade. hardly any dust. when blade has no more teeth left, a 1mm cutting disc cuts new teeth. rough, but will do for more plaster cuts.
Borrowed from a mate a hilti chaser and dust extractor for one job we did in a basement.
Excellent bit of kit, best Ive used but if £600 is too much then the Hilti is not for you!!!!
We use 2 different sized festool vacs. They have remote starting from either mains or by Bluetooth switch if using battery tools. They get used with a metabo chaser that goes to 40mm or the festool dsc 125 which is a sort of angle grinder on its side that goes to around 27mm. I found somewhere that did reusable bags for a good price. We get about 5 refills before the bag zip fails on us. Cheaper than the festool reusable bags.
Would you be able to post a link to the items you used online? Thanks pal
