T
TPES
Just a quick one for you..
I have been asked on the phone to come and install a new feed to a porta cabin & test once complete,
A tempory armoured feed will run from existing building and hook up to the CU in the cabin, I think im right in saying i need to TT the cabin if water services and extrenous parts within.?
Also when it comes to testing, I will test the armoured feed installed to the cabin, which will be an EIC. will i need to PIR the cabin it self ?? or not test anything within the cabin?
EIC for the supply as this is more comprehensive certificate than MWC, and the cabin should have an in-date periodic if hired or you may well have to do this too :D
I would TT with the earth seperation at the Cabin to protect the SWA.
Ive just read back the title i put to this topic.
I have no idea why i headed it "Which certificate would you use"..
Thats not what i meant to say... Doh!
PIR every 3 months the inside and supply although inside will probably be under the hire companys responcability
Old thread I know..
Ze is taken from the origin..right.. I would take my earth resistance from my rod, right?
On the cert "Supply protective device" this would be the MCB protecting the SWA supply?
On the cert "main switch or circuit breaker" this would be the main switch within the CU in the cabin?
On the cert "nature of supply parameters" PFC taken from the MCB in main sub board within the main building..?
Just need clarification on these few bits, hearing different methods from different sparks still..
