Hi Benzo, welcome to the forums.
On the speakers, there is going to be a ratings plate which provides details of the power consumption etc. Can you take a photograph of it and post the photo?
Depending on the type of power supply (which is likely to be switch mode these days, but may not be for audio gear) it may operate quite safely on 240v @ 50Hz. But we would need to see the ratings plate to be in with a chance of providing an answer or further guidance.
The US uses 120v mains, so presumably you will need a 120 volt transformer. A good, but bulky, source would be a 110v site transformer available from Screwfix, Toolstation etc. (110 or 120v is neither then or there).
But someone is lying on the spec. It claims 1000w output but only 450w power use!
Site transformers are not rated at continuous output so get one rated at around 1000 VA.
DON'T just change the plug. 240 volts will kill, a plug does not know what the voltage is.
I have not yet received the item its currently in transit. I did find an online manual though: Samsung MX-F830B.pdf - https://www.scribd.com/doc/299509455/Samsung-MX-F830B-pdf The name of the device is samsung MX-F830B.
It does not quote the input voltage/frequency but it does say:
Dual voltage X.
Which I presume means No.
Why did you buy a US model, it implies a European model is available? Does it include the AM tuner option? If so the channel spacings will be wrong for Europe!
Dual voltage X.
These Hifi systems are really hard to come by these days because Samsung have discontinued the range. I actually had bought a model similar to this one but it was a UK model, but the speakers went missing mysteriously in transit. So I was left with no other choice. I think it only has FM as it comes with an FM antenna and not the AM/FM Antenna as can be seen here: https://i.Upload the image directly to the thread.com/89x1VjG.png
komtwp
The FM de emphasis will be wrong as well, 75µS instead of 50µS. It may sound a bit dull. Another possible problem is that it may only tune in 200kHz steps, 88.1, 88.3, 88.5, 88.7 etc. Stations on a even number of 100kHz, e.g. Londons Capital Radio on 95.8 will not tune in properly.
These type of equipments really should not be transported across the Atlantic.
Do you still have the UK model minus speakers? You could use the speakers from this one with it and solve lots of problems.
No I don't I sent it back, so I could get the refund. I don't really mind not having the radio ability because I don't listen to it. I had my eyes set on this Step Down voltage: https://www.amazon.co.uk/gp/product/B00DY81KRW/ref=ox_sc_act_title_1?smid=A2F7DZHCHJJNA6&psc=1
It it really is a transformer OK. But I doubt it is as it has voltage converter written on the front panel. Voltage converters are basically a switch mode power supply and I wouldn't use one for any delicate electronics.
The site transformers I previously mentioned are a similar price and are genuine transformers.
I think the word 'converter' is just used as not everyone will know what a transformer is in the electrical sense.
Sorry for being stupid here, but is this the one you are talking about this one : https://www.screwfix.com/p/carroll-...0v/60761#product_additional_details_container
