By the time you buy new drivers and alter the wiring to suit.... Only for the lights themselves to start dropping like flys at some point, it will surely be cost effective to replace with something else?
If you do want to go the driver route a good brand is meanwell. Youll need to calc your requirements from details you have on the lights, bearing in mind maximum runs etc from the drivers.
Yeah I’ve been on the website and i get lost halfway through trying to work it all out
I don't think you will save yourself any money or hassle, by doing what you are proposing.
Matching drivers to LED lamps is not such an easy process from what I've read. As said you would also need to consider the spec of the cabling from the central driver to each lamp, and the inrush current with a central driver. Even manufacturers get things wrong. If you are adamant in doing this, I would recommend speaking to a UK led driver manufacturer/supplier.
As the others have said, take a hit and slowly replace each room, with some quality UK sourced down lights, most come with an extended warranty.
I might be wrong but i think you'll struggle to get 15V output. It's a bit weird they're not 12V.
If you want to look at replacing the fittings please let me know what you need and as a forum sponsor I'm sure we can help to make is as painless on your pocket as possible.
Maybe something like the Ansell Prism would be suitable.
  • LED dimmable fire-rated downlight for domestic applications
  • Supplied with matt white bezel as standard
  • Integral driver with push-fit loop-in, loop-out terminals for ease and speed of installation
  • Fully tested for 30, 60 and 90 minute ceiling types to meet Part B of Building Regulations
  • Fully tested to meet Part C (moisture) and Part E (acoustic) of Building Regulations
  • Wide 60 degree beam angle for increased light distribution
  • LED lifespan L70 40,000 hours
  • supplied c/w Integral driver
If you do not need the lights to be fire rated there also some very well priced offerings from Ansell and JCC available.
Cheers,
Ivan
If you want to change the drivers then you will need to know the specifications of the LED itself. It may be that the drivers that you currently have are fine quality wise but are overloaded, or not correctly matched and that is why they are failing. If you replace like for like but with a more reliable model they may fail as well.
Personally I would take it as a lesson learnt and replace the lot. The old adage of buy cheap buy twice seems to spring to mind unfortunately.
