diyterry
Morning, hope your all well. Is it okay to run a 2.5mm and a 1.5mm cable through the same 20mm conduit?
Yes indeedI take it, you mean T&E cables?
Yes you can run 2 T&E cables through conduit.
I was just being lazy and run one length of conduit, but having tried getting two lengths of cable through the conduit I am going to put two runs of conduit in.As conduit is designed for singles cables it's not intended to be restricted to only one cable. But you haven't stated what it is you're trying to achieve.
Or lube.You could use 25mm conduit instead![]()
Pulling lubricant? Thought that was just another name for vodka.
