S
Simon0211
I have a few Questions about the Dimplex Quantum range if anyone has experience with them?
I presume the units have in built thermostats....if so will they ‘switch off’ when the room temp is met to conserve saved heat?
If the heat stored overnight isn’t used up in the day, are they clever enough to use less energy storing up the following night as there’s already some heat present?
How do they know when to start and stop storing heat - how do they know when the economy 7 hours start and finish?
If you tell the heater that you want a couple of hours heat first thing and then a couple last thing (in the bedroom for example) will they only store up the heat for this amount of time?
Thanks, hopefully some light can be shed on stuff that I can’t find online!
