Deleted member 26818
That page lists them as Class 1.
You can see the sheathing at the top hole, even looks like a bit of heat shrink on the end.You need to know the construction of the conductor, the insulation may be reinforced.
Might be designed as double insulated, but it hasn’t been constructed as such.It's double insulated the sign says so, so end of controversy.
all the op could do is earth the back plating that is on with ring crimp ,but if he takes it off at some time the front light fitting will not be earthed .Just the block connector renders that Class I.
