Changed 4 way hook up box with individual 16A RCBOs in box,
Part 1 is description of works all good
Part 2 is earthing and bonding yes
Part 3 Circuit details so this is what feeds the box? And the fuse/mcb
Part 4 is test results for circuit altered or extended so these are my results for feed cable and RCD times what have you
Yes again
What's a hook up panel?
I use Hollycroft software certs and they do a
MINOR ELECTRICAL INSTALLATION
MULTIPLE WORKS CERTIFICATE
This gives up to 6 different minor works on 1 certificate, quite handy at times but the results sheet is the same as an EIC so a bit more to fill in.
London
Minor works certificate
Bradley6969,
loplug,
