Discuss Minor works certificate in the UK Electrical Forum area at ElectriciansForums.net
Changed 4 way hook up box with individual 16A RCBOs in box,
Part 1 is description of works all good
Part 2 is earthing and bonding yes
Part 3 Circuit details so this is what feeds the box? And the fuse/mcb
Part 4 is test results for circuit altered or extended so these are my results for feed cable and RCD times what have you
Yes again
What's a hook up panel?
I use Hollycroft software certs and they do a
MINOR ELECTRICAL INSTALLATION
MULTIPLE WORKS CERTIFICATE
This gives up to 6 different minor works on 1 certificate, quite handy at times but the results sheet is the same as an EIC so a bit more to fill in.
The minor works forms that I have used have been for either single circuits or up to three circuits more than this I don’t use minor works.
Would you replace a cu and issue 10 minor works certs?
What do you use then?
Reply to Minor works certificate in the UK Electrical Forum area at ElectriciansForums.net
Seeking advice, we have been replacing extractor fans for a local council and was originally told no ‘like for like’ replacement works needs a...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi Everyone, This is my last question/post for tonight, promise. Please can I ask for a little advice on certificates as I am now questioning...
Hi, can someone give me some advice RE completing a small works certificate for a fused spur coming from a ring final. 1) In part 2 of the AMD2...
7K
