Explain please, a picture of what you are suggesting will help.hello guys
I quite often find that when terminating 25mm tails into a 100a fuse board isolator you do not get the 25mm tails to squash nicely by the main switch thermals like you would 16mm tails, should be be using copper blade terminals instead to ensure a better connection?
Thanks Westy
From Westies info then no unless the terminals are designed for flat cables imohello guys
Or have three shredded wheat for breakfast with spinach for the evening meal.No problem using 25mm tails. Just form them properly, set them in the terminals, then re-tighten after they have settled a bit.
If problems persist try an extra weetabix in the morning.
As long as there is no risk of galvanic corrosion
