Discuss Should we use copper blade crimps? in the UK Electrical Forum area at ElectriciansForums.net
hello guys
I quite often find that when terminating 25mm tails into a 100a fuse board isolator you do not get the 25mm tails to squash nicely by the main switch thermals like you would 16mm tails, should be be using copper blade terminals instead to ensure a better connection?
hello guys
Explain please, a picture of what you are suggesting will help.
Thanks Westy
hello guys
From Westies info then no unless the terminals are designed for flat cables imo
You shouldn't need to if as I think you are referring to a domestic consumer unit 100A main switch it should be designed to take 25mm tails.
You shouldn't have problems terminating 25mm tails into a switch. If you are then you are doing something wrong.
You need to use your hands and form the cable correctly so it simply drops into place without putting strain on the switch and then tighten.
Reply to Should we use copper blade crimps? in the UK Electrical Forum area at ElectriciansForums.net
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi, I was wondering if the wylex/Proteus SPD Isolators where dual isolator, they have 4 terminals at the bottom, can you use them to take 2 sets...
Joining niceic and doing a sub main to a garage off a tns earthing arrangement using 6mm Swa. The question is I have 25mm tails on 100a main fuse...
I've been carrying out quite a few domestic extension first fixes recently which involves providing a power supply installed from the properties...
