B
Barnaby Stedman
CK Cable Shears 210mm - https://www.test-meter.co.uk/ck-cable-cutter-shears-210mm/
Those are the ones I use or at least they look very similar.![]()
I always wonder where they get the max 16mm from. I've used them on 35mm and it's been fineI can't find the CK exact ones , very similar to these .
As @Dobes_88 The knipex Installation pliers are very good too , but are only recommended up to 16 mm .
The CK of the link I have posted do two sizes , 16mm and 25mm.
https://www.amazon.co.uk/C-K-39064-RedLine-Cable-Cutter/dp/B002JCTIOG
I know , probably just to cover themselves against warranty claims.I always wonder where they get the max 16mm from. I've used them on 35mm and it's been fine
still going strong.I always wonder where they get the max 16mm from. I've used them on 35mm and it's been fine
Could be, I didn't know that to be honestAren't they referring to the diameter rather than CSA?
