If you talked through with the customer about their choices re RCBO and RCD CU's and explained how situations like this can occur (nuisance tripping/earth leakage) I dont think you owe them anything unless they want you to investigate at their cost.
If on the other hand you didn't talk through options then they are going to blame your work so you'll need to find the faulty appliance/fault at your cost.
Previous advice is as ever, great.
Good luck.
And serious hassle when it starts tripping ...
Fitted many hundreds, and never had any serious hassle..
Had the odd issue where a neutral has been crossed over to wrong side and that’s about it.
What are your thoughts on very high earth leakage currents upstream of the consumer units?
I've done so much fault finding on existing installations over the years on single , split and dual RCD boards I stopped fitting them at AMD3
RCBO boards are far easier to test, now and in the future ............
Its not about hassle for me, its about saving clients serious trouble, and costs going forward.
As for upstream earth leakage - not come across this .................
So it works out cheaper to buy RCBOs as a CU package and just put the CUs to one side.
And you can take out the RCBO's you don't need, then when you have enough stock simply buy a bare chassis with DP switch and use the spares ......... kerching.
Well just for the record, I’m all for RCBOs too..
Next time you get chance do a few tests upstream and observe the earth leakage.
Think you will be surprised by how high this can be, especially on large installations.
