I can't work out how the removal of light fittings has lead to so much cable hanging about like that. They look as if they had never been fixed
I don't think it has been mentioned but those cables may very well have been made safe by disconnection and the electrician be taping them up to stop corrosion
If that is not the case then the comments previous may be justified
Good observation. These cables are all LIVE, they used to feed a permanent outside light and an emergency light. They are connected direct to the internal 24Hr. lighting circuit.
then whoever did that wants his arse kicking. they should have been either locked off or dissed from MCB/s, and preferably the N also.
I wouldn't even leave that for 6 hours, never mind 6 months. I don't think they ever intended to come back to finish the job. Did you get an electrician to sort it out? Where are you based?
Thanks for all your replies, it is still ongoing, I am awaiting a reply from the "Management Committee"
Another couple of pictures attached.
50401
50402
While the electrics don't look too clever I think I would be questioning the suitability of the fixings that are holding that steelwork
It's a complete bodge , if there is no plate on the inside those bottom bolts are on the edge of the bricks , OK it might have a support upright , but it is not ideal.
