Discuss Advice and information in the UK Electrical Forum area at ElectriciansForums.net
Brunel
A bit of background info. I live in a flat complex, approx. 6 mths ago some building work was carried out which necessitated removal of some external light fittings pending full completion of the work.
An electrical contractor was employed for the removal and making safe, until the work was completed.
Six months later, for reasons as yet unknown, the work has not been completed and the temporary electrical work is still in situ. I and a few other residents have queried whether the temporary electrical work is safe, the cables are of course outside, and are only covered in plain brown electrical tape, please see attached picture 1:
50358
Today the electrician was on site for other work and also added some extra tape and a plastic bag to the above cables and to another cable in a different position. These cables are within touching distance of anyone walking past. Picture 2:
50359
Picture 3:
50360
I realise that the work is only temp. Do I have good grounds in raising a serious safety issue to the management company?
Thanks for any response.
That wants reporting and sorting out. Who on earth would leave it like that. How long would it have taken to use an IP rated Junction box. Probably took longer twisting the cables up and wrapping them in tape.
Well it confirms one thing that wasn't done by an electrician. Someone masquerading as one but something completely different.
From day one that is a bodge , Those cables seem to be trapped against the metal framework of that structure , lets hope they don't chafe through and electrocute someone.
Perhaps someone was trying to bond that hanging basket bracket. Mr Cockburn maybe?
I don't think it has been mentioned but those cables may very well have been made safe by disconnection and the electrician be taping them up to stop corrosion
If that is not the case then the comments previous may be justified
Good observation. These cables are all LIVE, they used to feed a permanent outside light and an emergency light. They are connected direct to the internal 24Hr. lighting circuit.
then whoever did that wants his arse kicking. they should have been either locked off or dissed from MCB/s, and preferably the N also.
Reply to Advice and information in the UK Electrical Forum area at ElectriciansForums.net
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Alright everyone, Got a question and looking for some of your opinions. My brother is a qualified electrician and I'll be asking him the same when...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
