J
Jsafe1969
Emergency light remained on when power reconnected.
Switched to off, now not working.
New battery, supply 232v, fuses ok. LED indicators not on
Any suggestions, thank you
Not really much to go on from the brief description, you could perhaps include a photo of the light & electrical connections.
No light and no LEDs lit - have you checked any voltages?
Input from consumer unit 232v ac. New battery fitted as I though that could be the issue.
[automerge]1577840699[/automerge]
Thanks, I will post later today.
No indicators led lit. Input voltage from consumer unit 231v ( we are on 230/50hz supply. Voltage (DC) from battery 13v. Fuses input & 12v ok.I tried resetting mains supply after fitting battery. When original power was restored emergency light remained on. I turned off at system pane, hasn't worked since.
cheked fuses on PCB? if they're OK< then the PCB itself is goosed. replace fitting.
