B
BCM454
Hello, my contactum b8003/2 30mA RCD feeds about 6 MCBs for light and power. Nothing had changed but suddenly my dishwasher seems to be the common denominator in tripping the main rcd. However, if I turn off all other MCBS, it doesn't trip. Please help me with my logic. This makes me think that the dishwasher, in combination with other things is now exceeding 30mA or whatever actual trigger leakage current of the main rcd, or the main rcd is now over-sensitive. I only put my dishwasher on overnight, so apart from router, standby TV and a few chargers, nothing else is running, but of course the refrigerator or freezer could cut in at any time. I moved the dishwasher plug to a socket on a different ringmain on the same master rcd, and it still tripped, so I hope there is nothing dodgy (mouse nibblage?) with its normal ring main.
Grateful to know if I put an rcd extension to test the dishwasher, would it or the main rcd trip first or is it down to the specific trip characteristics of each rcd and most sensitive trips first?
I remember the electrician having a job wiring in the main rcd as lots of cables in the fuse box , so replacing main rcd might be too tricky for me. Ideally I would love to put it on its own rcbo to have 30mA leakage to itself, but that's a major rewire. Grateful for advice and logic check. I would like to be sure if the dishwasher has gone faulty before replacing it.
Many thanks
Brian
Many thanks
Brian
