I have the 10 and 13mm combined spanner which has proved very useful, the build quality is great and I’m tempted to purchase other sizes.
thanks Jason
U can get 10mm and 13mm in one opened ended spanner along with a 17mm and 19mm. Both of which I have and can say they are good value in my opinion.
These are non ratchet versions as far as I have seen.
I have a 10/13 open ended one. very well made but i still find it a bit awkward to use compared with a conventional spanner.
Mostly it is the DIN sizes you will see so most comon are:
M4 = 7mm
M5 = 8mm
M6 = 10mm
M8 = 13mm
M10 = 17mm
M12 = 19mm
M16 = 24mm
For the smaller sizes a 'nut runner' (screwdriver with hex socket) is often most useful thing, less chance of socket coming off as you would see with 1/4" drive set, etc. For an electrician I doubt you will see much over 19mm.
But, there is a whole lot of other sizes in use, so your M10 bolt might just have 16mm or 15mm size!
Also you will occasionally see UNF/UNC sizes and some metric spanners are often close enough, for example:
7/16" ~ 11mm
1/2" ~ 13mm
5/8" ~ 16mm
3/4" practically identical to 19mm.
But if you really want to impress the ladies you need these:
M4 = 7mm
M5 = 8mm
M6 = 10mm
M8 = 13mm
M10 = 17mm
M12 = 19mm
M16 = 24mm
7/16" ~ 11mm
1/2" ~ 13mm
5/8" ~ 16mm
Good post :)
That Bacho set has all the sizes in your post including 27mm . Ring only though.
seen them on ebay. sold individually. works about the same price when added up. sorely tempted.
You won't be disappointed. They pack fits in the pocket.
Amazon had the full pack cheaper than the ones in my link, they may well still have them.
I was wrong - They are the same price.
can't see me needing anything over 19mm though. might just buy one every 2 weeks or so, work is almost non-existent at present.
Typically the bigger sizes are way bigger for glands and similar but they are often stupid sizes that don't match any of the usual DIN bolt sizes, etc. Hence using adjustable or pipe pliers.
For example I happen to have a 32mm gland with an earthing nut on it, Sizes are:
45mm
43mm
46mm
WTF! Why can't they make them all the same A/F size?
8 to 19 mm £34 inc postage . Amazon.
Had these for years 0BA to 10BA. Got a ring spanner set somewhere.
Haworth,
davesparks,
