H
Haworth
Looking at getting some joker wrenches/spanners. Are they worth an investment?
www.kingdicktools.co.uk
Good postMostly it is the DIN sizes you will see so most comon are:
M4 = 7mm
M5 = 8mm
M6 = 10mm
M8 = 13mm
M10 = 17mm
M12 = 19mm
M16 = 24mm
For the smaller sizes a 'nut runner' (screwdriver with hex socket) is often most useful thing, less chance of socket coming off as you would see with 1/4" drive set, etc. For an electrician I doubt you will see much over 19mm.
But, there is a whole lot of other sizes in use, so your M10 bolt might just have 16mm or 15mm size!
Also you will occasionally see UNF/UNC sizes and some metric spanners are often close enough, for example:
7/16" ~ 11mm
1/2" ~ 13mm
5/8" ~ 16mm
3/4" practically identical to 19mm.
But if you really want to impress the ladies you need these:
Home | Birchwood Price Tools
seen them on ebay. sold individually. works about the same price when added up. sorely tempted.I have this set - 4 in one times 4 , not open ended but good quality , and a space saver.
Bahco Metric Ratchet Spanner Set, 8 - 27MM, Set of| at Zoro
Bahco - Metric Ratchet Spanner Set, 8 - 27MM, Set of 4 available at Zoro.co.uk - UK's Leading Supplier of DIY Tools and Supplies'www.zoro.co.uk
You won't be disappointed. They pack fits in the pocket.seen them on ebay. sold individually. works about the same price when added up. sorely tempted.
can't see me needing anything over 19mm though. might just buy one every 2 weeks or so, work is almost non-existent at present.
Amazon had the full pack cheaper than the ones in my link, they may well still have them.
I was wrong - They are the same price.
8 to 19 mm £34 inc postage . Amazon.can't see me needing anything over 19mm though. might just buy one every 2 weeks or so, work is almost non-existent at present.
